I’ve realized that MorphControl with a target curve laid in plane YZ has a strange behavior, here the images:
Here the code to reproduce it:
ObjRef[] curvesToFlow;
ObjRef objRefSourceCrv, objRefTargetCrv;
//Get Curves
if (RhinoGet.GetOneObject("Source curve", false, ObjectType.Curve, out objRefSourceCrv) != Result.Success) return Result.Failure;
RhinoDoc.ActiveDoc.Objects.UnselectAll();
if (RhinoGet.GetOneObject("Target curve", false, ObjectType.Curve, out objRefTargetCrv) != Result.Success) return Result.Failure;
if (RhinoGet.GetMultipleObjects("Curves To Flow", false, ObjectType.Curve, out curvesToFlow) != Result.Success) return Result.Failure;
//Flow Curves
var mc = new MorphControl(objRefSourceCrv.Curve().ToNurbsCurve(), objRefTargetCrv.Curve().ToNurbsCurve()) { PreserveStructure = true };
var outputCrvs = curvesToFlow.Select(objRef => objRef.Curve()).ToList();
outputCrvs.ForEach(_ => mc.Morph(_));
//Add to Doc
outputCrvs.ForEach(_=>RhinoDoc.ActiveDoc.Objects.AddCurve(_));
return Result.Success;
Is there a way to avoid that?.
Attached a dummy project and 3dm file
Thanks and best regards
Enric
FlowByCurve.zip (25.3 KB) Flowing Curves.3dm (269.7 KB)
