Hey there! I’ve got a problem with morphing/flowing a surface pattern along a curve/ along a surface.
In Screenshot 1 im trying to use the Box Morph node to project the given Surface pattern in the center of the picture onto the Domain Divided Surface, which itself works… It’s just that the orientation of the pattern, thats going from the right side of the Domain Box to the left, instead of project itself in the normals direction of the Domain Box, i.e. away from the center, and parallel to the Box outline. Haven’t found any solution to this yet.
In Screenshot 2 I was trying to project that Surface Pattern along a given Target Curve using Flow , but as you can see it didn’t worked quite well.
Why is the orientation of the stripes suddenly 90° rotated? And why does it look like it’s stacking up from left to the right? The Base Curve is exactly the line, with which I started the whole surface pattern. The Target Curve length is a little over 60, so I have two full segments, but it’s not working like I want it at all, as it seems its pasting one full clipboard, then stacking up a little for the second, and even more for the third paste.
If anyone knows how to cope with those problems, if its just the surface or the curve doesn’t matter, thanks for the advice!
