Morph on surface invalid
Hello friends!
Can you tell me how to apply the pattern geometry to a curved surface?
I used “Surface Morph” but it doesn’t work on the curved side.
How to properly lay the tiles on the surface, then cut out the unnecessary and bake?
01.3dm (12.2 MB) 01.gh (21.4 KB)
Morph on surface needs a reference surface, not a bounding box. Box Morph component needs a bounding box but since you are using Surface Morph, use a reference surface. Check out the tool tip videos for FlowAlongSurface if you are confused.
https://docs.mcneel.com/rhino/5/help/en-us/commands/flowalongsrf.htm
Thank! I’ll try to figure it out
