How to morph a mesh geometry on a curve
Hi to all!
I have been facing a problem trying to flow a mesh to a curve, to make a ring… the problem is if I use the flow component It flows the shape on front plane (vertical way) so it maintains the shape of the mesh but it is not oriented correctly on the curve… if I try the surface morph its oriented the way I wanted but it does NOT maintain the shape of the mesh, I already try with box morph and it didn’t worked either… I would appreciate your comments and help :slight_smile: thank you! I try to explain the problem the best I could, here I attached the file
1.4.3.gh (52.3 KB)
Hi, you can use Flow , I don’t remember if this component comes by default in grasshopper.
1.4.3.gh (44.6 KB)
