Hi, its been a long time since i posted something here.
just asking, is there a way to make grasshopper definition a “tool” that is always kept its parametric status and can be adjusted per object basis.? sort of like “MODIFIER” in other software.
reason being is that everytime we want to do repetitive task (for example, creating window mullion based on input surface). we need to open grasshopper first, then either create the definiton or import it from previously made one, then feed the input surface.
this in my opinion takes some time, and imagine if we are working on 50 different window mullion modules, we need to have those 50 GH definition in the canvas to make sure all those definition stays “ALIVE” (by alive i mean can be adjusted parametrically. not baked yet).
I was dreaming of a tool which can convert any GH definition into “Command” that will then be executed in those specific object. then those command can be stacked together (basically chaining the output-input of the GH). but in more intuitive, and simple “MODIFIER Stack” panels (some of u prob know what i mean if u hv used MAX before).
This Modifier stack is basically per object basis that is managble to a specific Tab (just like Block Tab for example with each GH modules (Modifier) adjusted on specific level.) the parameter is totally up to us that is easy to achieve with the current GH slider / input numbers, etc.
any way to achieve this? or at least considered to be part of upcoming tool release?
Thanks!
