Modeling this chair in Grasshopper
In a freelancing web an employer offered this shape to be designed. Before I can analyze it for designing with Rhino, he delivered the project to a freelancer (it actually is always so and my hook doesn’t catch even a small fish for dinner LOL)
Nevertheless, aside from earning, I want to know how do I can make this chair with grasshopper.
Thank you
Most likely, the original shape is made with Rhino
check / search for waffle structure of waffle script.
I need BB Waffle component, but I couldn’t find and download it anywhere.
You didn’t search enough
Thank you so much
I referred to Food4rhino and downloaded the plugin.
I don’t see a component named Waffle in Bowerbird. I already found a .gh file on the internet that used something called ‘BB waffle’ (the white component). Now, I tried to find a similar one in Bowerbird, but there is no component with this name to replace it with BB Waffle.
Please let me to send the pictures…
Hello, after download you have to install it. I am quite sure you didn’t or the file is blocked. Unblock the file. You must have this panel. Weaverbird and Bowerbird are not the same “bird”
Weaverbird and Bowerbird are not the same “birds”
yesterday, I copied Bowerbird.gha to C:\ …\Rhino\ components but it didn’t appear in grasshopper.
Today, I copied it to C:\ AppData.…Roamming.…\ libaraies
But it still didn’t appear in grasshopper, while I copied NGon.gha in Rhino components previously and it did work immediately.
Unblock the file. Right click on gha.
Excuse me senior, but what does mean right click on gha? When I do that only this menu appears
plugin
It worked !!!
images
Thank you so much, senior Delrieu and Hs_kim :slight_smile:
At present, I don’t check the solution box, because there are may some questions in the future.
