i made this three dome surface based in catenaryn
initial model grasshopper.gh (37.5 KB)
but i need to the the structure into a waffle structure where i can edit the thickness of the ribs (similar to this)
hi bigbankareus,
I would recommend you to try Bowerbird.
it’s a very easy way to generate waffle structures like that.I think it can even handle arbitrary planes.
Yep. See the example files.
BTW here‘s the latest waffle thread, in the modified bowerbird example definition I upload, you can also find solid 3D model
hi is there any way to make a hole in the surface and like its a hollow and the beams deviate around. Regards
