I’m making these tests by changing the Length / Width / Height slider values.
I know you usually need some minimal model, but in this case I’m just noticing an overall slow and unconsistent performance, maybe there is something that works fine on the PC but is causing troubles on the platform - and again without any error/warning available troubleshooting these issues takes longer than developing the model itself.
For the future, it would be really helpful to have some report with information on the solution, similar to Metahopper’s Bottleneck Navigator.
Thanks for your feedback. ShapeDiver will have better error reporting in the future.
How long does it take to open your definition locally?
Also, I noticed you are using opacity map for the pattern on the pergola. Large textures embedded in your model can also cause problems, more in this post:
The original model takes 2.6 seconds.
The simplified version - which has several features disabled, including the opacity maps - takes a very short time (it’s not even reported in Grasshopper’s status bar) - well under half a second.
I’m testing them on a very standard PC by the way (i7 4770 with 32GB of RAM)
The model is using a single opacity map - a 512px wide png file under 25 KB in size. The texture is then tiled and applied to several simple meshes, which are in turn instantiated using ShapeDiver’s transform scrript. Is this supposed to create problems? Should I just make “physical copies” since the meshes are very simple?
It seems that you did everything right, the texture is really small and it shouldn’t cause any issues. Opacity map is definitely faster than creating real meshes here so don’t change anything in your model.
You probably experienced some performance fluctuations on our servers. While we do our best to minimise them, this might still occur and our dev team will investigate further. Please let me know if your models don’t perform as expected.
I have been doing some testing using this model, and also checked the computation logs (which in a few weeks will also be accessible via our new platform). We keep quite detailed information in these logs, like:
how long did the computation take (pure computation time, from setting parameter values until the Grasshopper computation finishes)
did the model have to be opened newly (which means extra time for loading the model, which is also recorded), or was the request processed by a worker which already had the model loaded
how long did the request have to wait before being processed by a worker
how long did it take to save the results of the computation
etc
The logs for this model typically show pure computation times between 0.5 - 3 seconds. Opening the model the first time took about 3 seconds. I saw that about 10% of the request took up to around 10 seconds pure computation time (there are about 40 requests logged so far).
As mentioned above, soon you will be able to see this data yourself.
This model fails to open for me currently. This seems to be related to an issue with a texture image used by it, for which the download request times out. Did this model work you previously? I will dig into this.
A quick update about this issue: today I uploaded a slightly different version of the same definition (ShapeDiver - Online Parametric 3D Configurator) and once again I ran into a computation time beyond the 10 seconds limit - on the local computer it still takes less than 1 second.
I setup smaller initial dimensions and disabled some geometric features but it didn’t work.
I also tried the new platform and got the same error.
For me the solution was to avoid the download of an external texture (which is in turn very small) by adding a toggle, which allows to download the texture only after the model is processed for the first time. It 's a bit of a hack, and I wouldn’t expect it to be necessary, but in this case it has worked.
Since it seems the first upload is quite critical, when there is a problem with the processing of external data (either geometry or images) it would be useful if the new report system could actually mention it.
What do you mean by downloading a texture? Are you referencing the url in Grasshopper and using it as the texture input, or are you downloading an image file using the import component and using the Bitmap object as input?
