when I rotate the model to view they disappear and instead boxes appear
Hello Maicon. This is a feature used for large models with lots at math data in them. See the image below. Uncheck âBBox Displayâ in the Display settings tab
Hmmm. Thatâs interesting. Sometimes the feature will activate on its own if the file is very large, but your model does not seem that complex. Try checking this setting un the options menu under display modesâŚmaybe its overriding your selection in the display panel? you Could try âRestore Defaultsâ at the bottom as wellâŚsave your file and reset Rhino might work
Also, please run the Rhino SystemInfo command and copy-paste the result here. That might show if something is up with your set-up.
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 4-20-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.59
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-20-2022
Driver Version: 30.0.15.1259
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\SN\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot11RhinoPlugin (55124e8a-aa81-4be8-8e12-9f452c473970)\1.0.0.0\KeyShot11RhinoPlugin\Rhino 7\KeyShot11RhinoPlugin.rhp âKeyShot11RhinoPluginâ 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp âWebBrowserâ
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp âRhinoScriptâ
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp âIdleProcessorâ
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp âLegacy Rhino Renderâ
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 7\Plug-ins\MeshCommands.rhp âMeshCommandsâ 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp âAlerterâ
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp âCalcâ
Is there some reason you chopped off the top part of the system info file? It also has useful info.
reset all parameters, apparently it works
@Maicon_Breier
I invite you to support the community that helped you by purchasing a legal software license.
