I tried it on Rhino 7, and the error seems to be similar. I don’t know if this is Rhino or the source file, but I do not have any other CAD software to give it a try.
which is typical for millimeter STEP files generated by SolidWorks. (The STEP file header states ‘SolidWorks 2023’.)
To import this file to a model containing only blocks containing error-free, closed polysurfaces, set testSTEPImportToleranceOverride Type=Override Tolerance=0.001
before opening or importing the STEP file.
(It does not import as well with 0.01 or 0.0001.)
The testSTEPImportToleranceOverride setting will remain in effect during the current instance of Rhino until it is set to another tolerance or to the default mode by testSTEPImportToleranceOverride Type=FromStepFile
