Kangaroo2 for mac
Hello everyone,
I’m trying to use kangaroo 2 on mac by opening a definition but an error message appear saying that some components are missing. The thing is that I have already installed kangaroo2 on grasshopper.
Do anyone know how to solve this?
Hi @grigoriadis.georges,
The components those errors are about are from the old version of Kangaroo.
If you post the file I can show how to do the same thing with the current version.
Hello @DanielPiker Daniel, thank you for your help
Here is the file
Mesh - Kangaroo Drape.gh (19.7 KB)
Does the name of the components has changed?
Hello @DanielPiker , Have find finally a way to solve this issue?
Have a look at the ‘Drape’ example here:
Thank you @DanielPiker
Also, here’s one using a much faster version of the solid-pt collide component.
Drape_example.gh (50.4 KB)
It uses a script though, for which you’ll have to set the assembly reference location when you open it, as described here:
Thank you Daniel
I have change the trajectory as explained in the comments but I have an error in the second script box:
Ah yes, it was using the task parallel library, which I guess isn’t available on Mac.
Here’s a version with that changed to a simple loop:
Drape_example_nonParallel.gh (46.8 KB)
It is working thank you! And how can i prevent it to go in the mesh ? And to make a drape of a box?
Here’s one that uses solid-line collision, which should do a better job of preventing it clipping through the edges. You can also use a slight offset of your solid to avoid this:
drape_lines_boxes.gh (18.5 KB)
Thank you very much @DanielPiker
Parallel threading is actually supported on mac. You just can’t access it directly and have to use System.Threading.Tasks.Parallel to access it…
Drape_example-mac.gh (54.5 KB)
Good to know, thanks!
