Hi Guys,
I have updated Rhino 8 and the Middle Click Popup has change to a narrow long vertical window. And when trying to re-size it it goes back to the narrow state. Any ideas? Or anyone has dealt with Middle Click popup toolbar. In rhino 7 this tools was more stable but in 8 it is not. The manual resizing was not effective from day one.
Regards
Majid
Hi @MAJID_DOOST
Which pop-up toolbar have you assigned to the MMB?
Pls also run _SystemInfo and post back the results.
Hi Gijs,
I have a customised toolbar (RUI) collecting all frequently used tools and through the tools / mouse I assign it to my middle click. Never had problem with Rhino 7 moving from one computer to another.
Here is the System Info.
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Evaluation, build 2024-10-08
License details: Cloud Zoo
Expires on: 2024-12-02
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 127GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 16GB, Driver date: 10-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.58
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-4-2023
Driver Version: 31.0.15.3758
Z-Buffer depth: 24 bits
Total Video Memory: 16380 MB
C:\Program Files\Veesus\Rhino\Rhino8\Veesus.rhp “Veesus Point Clouds for Rhino” 2024.3.8941.20140
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MPlane.rhp “MPlane”
I also encountered the same problem. Both laptops 8 and 9 have this issue where the middle button pops up as a vertical strip, while 7 can record the strip style of the middle button popping up,
Thanks,
The issue is known and high o. The list of things to fix.
For now see if this workaround helps:
Same problem, that fix isn’t working here. Hope the fix is quick, this makes my work process incredibly slow.
I don’t remember, can you roll back to a previous version easily? This is painful. ![]()
@heath van you post your _SystemInfo
I might be wrong, but I am not aware that this is something that was broken recently.
License type: Commercial, build 2024-10-08
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 63GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 9-5-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 561.09
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 10-3-2022 (M-D-Y).
> Accelerated graphics device with 5 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 9-5-2024
Driver Version: 32.0.15.6109
Total Video Memory: 24564 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.3.0
First time I have ever had this issue. Started when I said yes to “update ready, install now?” or whatever that prompt is when you close rhino and there’s an update available.
@heath could you run _Reset, hit the “Save settings for support” and send the resulting zip to me by pm?
thanks!
Done. ![]()
now logged as:
RH-84339 popup toolbar size is off with text button
Hi
I have updated Rhino 8 today and still have the middle click pop-up size issue. Any other updates coming soon?
Regards
Majid
I’m still working on this one @MAJID_DOOST
Hi Support Team,
Any update on this one? It is getting very frustrating having this middle-click pop-up issue. Jus recently update no changes yet.
Regards
Majid
I would like to second this. l prefer to use Rhino 7 on my personal laptop, but I have to use R8 on my work laptop and it’s still annoying to not be able to resize any popup toolbar. It really hinders the flow and messes with my spatial memory of where certain buttons should be. Could we have a fix for this out sooner rather than later please?
Hi Team,
Is this issue resolved. I still have that weird long pop-up menu with middle click.
Majid
Hey @MAJID_DOOST,
Not yet, as you can see in the ticket it’s marked Open. When the ticket is completed this thread will be updated automatically with which version it is fixed in
I hope to fix these issues soon.
