Rhno 5 project. Working on a file with dimensions called out in inch-decimal form. How would I change this to inch-fractional?
Seems basic, but I have tried various approaches without breaking through. .
For example, I can go into File/Properties and open annotation, click on inch fractional, alter the size – then click Okay. Nothing happens next.
When I go back to the file, it still shows the dimensions in inch decimal form.
Have also tried going in through the dimension menu and altering the dimension style there… Again, the dimension style does not change in response to my entries.
Stubborn problem. Help does not shed any light on it. Must be missing a step or two.
Should I create a new file and template and import the old file to it? Would that work? Or can the dimension style and size be changed somehow within the existing file?
Thank you for your insights.
Michael
