Dimensions in fractions
I would like dimensions to be displayed as fractions, any suggestions?
Hi sailhighc,
You can change this display setting in the dimension style as shown here…
Thanks for the reply , How do you get to #1?
Step 1 in Brian’s example is in the properties window after you select a dimension you have already made. If you want to change just the dimension you have selected, use the button he circled, if you want to change the style so you get fractions for all the dimensions you are placing, you can use the Edit Style button. You can also get to these via Rhino Options -> Annotation -> Dimensions -> [Style you want to edit]
