This is a V6 file, and if I open it in V7 WIP the metal material looks a lot darker.r6 version.3dm (8.4 MB)
Peter
Actually, I can’t repeat this. I would expect there to be a little bit of difference between the two, but not much - and that’s what I’m seeing. Are you sure you are capturing the exact same file with the same view on both versions of Rhino?
- Andy
Huh, well your images still show significant difference between the two, but not as much as mine. Or maybe it is as much & it’s just an illusion.
I’m using the same display mode (exported from V6 & imported to V7) and the same file.
When I look at your examples more closely, they look very different.
Yup. Like I said, I would expect differences, but not dramatic differences like you show.
So…you have a custom display mode? I’m going to need that too if I’m going to repeat the problen
And just so you know, we are using a more physically correct method of calculating metallic roughness v7. That’s why there is a slight difference.
We also calculate the diffuse IBL slightly differently (better) in v7, which affects these kinds of unpolished metal effects.
Basically, I just want to make sure it’s intentional, not a bug. If it’s intentional, I can just adjust materials, etc, to make it the way I want it. If it’s a bug, I don’t want to go to the trouble and I’ll just use V6 instead. Sounds like not a bug. Anyway, here is the display mode, but it seems the same in all rendered modes that I use.testmode.ini (11.4 KB)
