The message appears when trying to insert text or edit the text in the 2nd leader.
Hi Dave - please run SystemInfo in Rhino and copy/paste the results here.
Rhino 8 SR7 2024-5-17 (Rhino 8, 8.7.24138.15431, Git hash:master @ 03702f889bdef32626af4bca510b5e8a85666d38)
License type: Commercial, build 2024-05-17
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
Accelerated graphics device with 4 adapter port(s)
Windows Main Display attached to adapter port #0
Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\import_SKP.rhp “SketchUp Import”
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24138.15431
Thank you for responding.
Dave
HI Dave -
Does this happen when you start a new file from a factory-default template and then run Text? Or is this specific to a file that you are using?
I just tried a new template and it worked as expected. So, it must be file specific. Now, the question becomes, is it possible to create a new file with the work I’ve already done?
Today, I am unable to edit anything while trying to edit text in my Rhino software. An error message appeared during the attempt, and I have attached a screenshot for your reference. This issue is affecting my workflow, and I kindly request your immediate assistance in resolving it.
Hi Muthukumaran -
I’m not seeing that screenshot here.
Please run the Rhino SystemInfo command and copy-paste its output here.
If this is something that you are only running into with a specific file, please also attach the file here.
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: Intel(R) UHD Graphics 730 (Intel) Memory: 2GB, Driver date: 6-8-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 32.0.101.5542
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 32.0.101.5542
Driver Date: 6-8-2024
Driver Version: 32.0.101.5542
Total Video Memory: 2097148 KB
C:\Users\Muthukumaran D\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\xPoints4Rhino Export (ec34c511-39b8-4e2b-8acc-f3523d63f8e9)\1.0.22.301\Rhino 7\xPoints4Rhino Export.rhp “xPoints4Rhino Export” 1.0.22.301
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
Thanks for the SystemInfo and the screenshot.
You didn’t post a 3dm file, though.
When you launch Rhino with a factory-default template and run the Text command, are you then seeing this error message?
-wi
yes after i get this issues
how i resolve it
Hi -
I don’t understand what that means.
I’ll need your 3dm file…
Untitled.3dm (71.0 KB)
3dm file upload above please check
Hi Muthukumaran -
Thanks.
Editing that text object doesn’t seem to be throwing an error here:
When I open that file, though, I’m getting this notification on the command line:
Read 3 annotation styles that reference 3 fonts that are not installed on this device.
Annotation styles referencing a missing font:
Helvetica / Helvetica (Regular)
romsim / romsim (Regular)
WORKING / WORKING (Regular)
Missing fonts:
Helvetica (Regular)
romsim (Regular)
WORKING (Regular)
Do you also see this error when you launch Rhino with a factory-default template and create and edit text with the unmodified default style in that document?
Having this issue too now:
File that was working with no problems for days (that I can’t upload here) now asking for a font that is installed and was used several times before.
Command: _Open
Loading Legacy Rhino Render, version 1.50, Aug 19 2025, 13:16:38
Read 8 annotation objects that reference 1 font that is not installed on this device.
Missing font:
Gotham Medium
Creating meshes… Press Esc to cancel
Successfully read file “C:\Users\user\[hidden].3dm”
Command: _CommandHistory
On top of laggin to show the font list, Rhino is missing some of the installed fonts
Sysinfo:
Rhino 8 SR23 2025-8-19 (Rhino 8, 8.23.25231.13001, Git hash:master @ d497625fea613f7e82b069cfb75ea737fd1aed0d)
License type: Commercial, build 2025-08-19
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.19
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 1-23-2025 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 12-9-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.41
Integrated accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 2x
Render version: 4.6
Driver Date: 12-9-2024
Driver Version: 32.0.15.6641
Total Video Memory: 8 GB
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.23.25231.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.23.25231.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.23.25231.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.23.25231.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.23.25231.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.23.25231.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.23.25231.13001
C:\Program Files\Rhino 8\Plug-ins\import_GHS.rhp “General Hydrostatics (GHS) Import”
