Hallo, just installed Rhino 6 and want to use the text tool. Doesn’t work at all. Not while using the tool button nor typing text in the command line. How can I get this solved?
Hmm, hard to diagnose this just from the problem description, do you have any further info? Where does it actually fail? Error messages?
If you type _Text, does the dialog come up at all? If so, when you type some text in the box and hit OK, do you get back to the Rhino window with a prompt for insertion point?
Just for good measure, perhaps type SystemInfo in Rhino and post the results here…
–Mitch
Hi Sascha,
one customer reported me, that this should be fixed in the latest version 6.2. Not? What version do you have?
Thanks
Michael
www.flexiCAD.com
Rhino 6 SR2 2018-3-6
Sorry, but nothing at all happens. No dialog box.Once I typed ‘text’ it’s waiting for a new command. Same with using the text tool.
Rhino 6 SR2 2018-3-6 (Rhino 6, 6.2.18065.11031, Git hash:master @ cd4fa1dcdec31cb58baacef0855771173af7196f)
Windows 7 SP1 (Physical RAM: 64Gb)
GeForce GTX 1070/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 388.13)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-27-2017
Driver Version: 23.21.13.8813
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files (x86)\Rhinoceros 5\Plug-ins\BoltGen.rhp “BoltGen”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\import_STEP.rhp “STEP Import”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2017.10.16.484\SectionTools.rhp “SectionTools”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18018.1000\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5”
OK, that’s weird… Does restarting the computer help?
Nope. Happened last week the same.
A shot in the dark: Could it be that the test dialog box is coming up BEHIND something else on the screen?
Also: when you start to type “text” in the command line, does the dropdown autocomplete list show “text”? What happens if you click that instead of typing the whole word?
Yes. it does autocomplete, but doesn’t change a thing.
Hi Sascha - thanks for the report, I’m checkin with the developers. In the meantime, can you try the SR3 candidate, by enabling ‘Release candidate’ in Options > Updates and Statistics > “Update frequency”
@Sascha_Holland-Kuhn - your Windows is 7, SP1 - is there some reason not to update to SP2?
Good morning Pascal,
doesn’t work too. Same, same.
Sascha
I can’t tell from your answer - have you updated to Win 7 SP2?
I have noticed the reference to Win 7 SP2 a couple of times today.
What was labelled as SP2 was a “convenience” method of all updates since and including SP1.
My system is Win 7, completely up to date, and is listed as SP1.
https://answers.microsoft.com/en-us/windows/forum/windows_7-update/how-to-obtain-and-install-windows-7-sp2/c2c7009f-3a10-4199-9c89-48e1e883051e
Barry.
Yes. I checked. All up-to-date now. It still doesn’t work. Type in ‘text’ – waiting for command.
What is a text tool? Text command and TextObject command work fine on my computer. I use Rhino 6.2 (2018-3-6).
Lucky you. On mine it’s not working. I am using Rhino 6 SR3 2018-3-13.
What happens if you type in -Text ? (with the dash in front)
Doing this I can modify the settings (stile, height, rotate) But I cannot generate text.
What is not working?
