Mesh no longer displays Layer Color after latest update
After the latest update, meshes no longer seem to display the color assigned by their layer in the viewport.
For example, in the video, the mesh should appear green because it is on a green layer, but it always displays with the default mesh color, even if I move it to layers with different colors.
I also noticed that, previously, when selecting a mesh it would turn yellow, whereas now its appearance remains unchanged. This second issue doesn’t really bother me as long as the Gumball still clearly indicates that the object is selected.
Has something changed in the display settings, or could this be a bug introduced in the latest update?
Work In Progress
(9.0.26167.11545, 2026-06-16)
Looks like it’s working fine on my end in the same Rhino WIP version. Could you share your current 3dm file? Thanks.
Zeppa-1030_n41_bug mesh.3dm (14.7 MB)
It’s working normally on my end. Could you run the SystemInfo and past all the popup contents? Thank you.
How strange!
Rhino 9 SR0 2026-6-16 (Rhino WIP, 9.0.26167.11545, Git hash:master @ 57b70c19c1a95d556312e40efd60cd1c4e9f7aaf)
License type: Commercial, build 2026-06-16
License details: Cloud Zoo
Expires on: 2026-07-31
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 1-20-2026 (M-D-Y). DirectX(11)
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26167.11545
C:\Users\Daniil.PC-DANIIL\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
@jessesn I just noticed that when opening another file, the surfaces also remain the same color, even though the layer color is different.
I took the same file, opened it in Rhino 8, and everything is fine.
Zeppa bug srf e mesh colore.3dm (424.6 KB)
Please try switching the GPU Technology option from Direct3D to OpenGL
Look, I did it, but I noticed it only happens in Shaded mode. When I switch to Transparent mode, the color is displayed correctly, and it also appears correctly in the other display modes.
The issue only affects surfaces and meshes. Curves and points change color correctly.
Could you try to reset the Shaded mode setting via the Restore Defaults ? Thank you.
Solved with Restore Defaults, but afterwards I set my Shaded display mode back the way I had it before: hidden isocurves, a different color for backfaces, and surface edges always displayed in black regardless of the layer color.
customized
Thanks, @jessesn
Hi
Has this also been solved?
No, now that you’ve made me doubt it, I checked the shape and the color doesn’t change.
@RedAlert @jessesn
Zeppa 180226_Serie_forma bug mesh color.3dm (16.5 MB)
But it only happens on that model.
The mystery thickens: two meshes on the same layer, one takes the layer color, the other doesn’t; even the shoe geometry remains a different color.
Zeppa-stranezza colore layer.3dm (14.3 MB)
I found the issue with the wedge: it was set to “Custom”. I changed it to “Layer”, but the same applied to the shoe shape as well.
