Unable to change layer color by clicking the little square
Hi, I recently switch to Rhino 8 and when I try to change the color of a layer by clicking on the little colored square beside the layer name nothing happens. I have to click with the left button and select “properties” and then “color”. Funny thing is that it happens only on certain random layer.
Anyone can tell me why?
Thank you
Michele
I’m having this problem. Any discussions or guesses as to why this started happening? I’ve been on rhino 8 since it was first released and this is a recent occurrence. Possibly since the last update. I created a new layer and moved the items in the previous non function color layer and the color started working, however, it did stop after a bit of time once I had moved the items to that layer. It is just one layer for me.
@estontw pls run _SystemInfo and post back the results.
@ufficio.tecnico2 is this still happening for you as well? pls also run _SystemInfo and post back the results.
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Commercial, build 2024-12-10
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-29-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.97
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-29-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.97
Secondary graphics devices.
AMD Radeon™ 610M (AMD) Memory: 1GB, Driver date: 5-7-2024 (M-D-Y).
Integrated accelerated graphics device with 5 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-29-2024
Driver Version: 32.0.15.5597
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\RhinoCAM 2023 for R8\RhinoArt1FileExporter For Rhino8.0.rhp “RhinoArt1FileExporter”
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24345.15001
C:\Users\eston\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
