Hei,
Why Layer settings does not apply colors to Geometry’s surfaces anymore (only edges)? In my case i want to the geometry to be fully red, not only edges.
Hei,
Hei -
That works fine in a factory-default set-up here. If you are using one of the built-in display modes, I’d try resetting that.
Hi @anon76319893,
This looks like another example of your post Rhino object colors. Did you not update Rhino to the latest release to fix that?
You need to be on Rhino 7.30.23125.15001, 2023-05-05.
If you’re already there then you have another problem, so let us know.
Regards
Jeremy
It is working now after second update. Thanks!
