Good afternoon,
I have a mesh that I imported into Rhino that wont show the materials in the material viewer. It will only show the material in render mode and shows all white in raytrace mode. When I export to Lumion it also shows no materials. Can someone please help.
For Raytraced and Rhino Render in Rhino 7 and Rhino 8 to be able to render meshes with vertex colors you need to enable hidden materials. Run TestShowPrivateContent (doesn’t autocomplete). Then in the materials editor add a Cycles VertexColor material and assign to your mesh object.
It will now show correctly in Raytraced and Rhino Render.
I don’t know if Lumion is able to render vertex colors.
Thank you. That fixed the issue with raytrace. Do you know why it still shows with no material when I livesync with Lumion?
No, I don’t know how Lumion handles meshes with vertex colors. You’ll have to ask the Lumion people.
