Mesh doesn´t trim
problem mesh.3dm (668.9 KB)
Hello all,
I´m having problems to trim a mesh. I tried MeshTrim with a plane and doesn´t work. The same with MeshSplit. Tried to SplitMeshWithCurve and also no results. Tried Boolean and the same.
Please Help!!
Your mesh has intersecting faces and normals that are not uniform. Whenever you have issues with a mesh just run the Meshrepair command to see whats wrong.
You can then use mesh repair to automatically fix those issues. Then it splits fine.
Thank you very much Michael, that solved the problem.
