IS there a tool which can make an in-depth analysis of a mesh? I suspect that there is something wrong with my mesh, but maybe it is other part of my grasshopper file. Just want to be sure.
Try the MeshRepair command in Rhino on your mesh.
then I dont know what was the problem if it was any
The MeshRepair in Rhino first analysis your mesh and then shows you the problem. After that you can exit the command if you don’t want to repair it.
