V5
I used _EdgeSrf tool (surface from 2 3 or 4 edge curves ). to fill the triangles at A B C D.
then join all surfaces, and unable to Mergeface those .
why ?
Mergeface fail.3dm (987.4 KB)
Steve
V5
why ?
Steve
Hello- if you are asking about MergePlanarFaces, this works on planar faces. The little surface is not planar.
so with cap they are planar, and with 2 3 or 4 edge tool they are not planar.
Hows that ?
Steve
my guess - there is some very tiny imprecision - and Merge(allCoPlanar)Face(s) does no t like it:
the boundingbox of this surface is not a rectangle and the dimension is
dimensions = 0.00006, 0.79360, 0.51130 inches
might be that Cap is only linked to document tolerance - but just guessing…
also it looks like pascal has found some im precisions…
