I’m having big problems with Rhino handling file sizes above 20 MB. I’m using Windows 10 corporate.
Rhino Version 5 SR14 64-bit (5.14.522.8390, 5/22/2017)
The geometry (one single surface with shape of a panel) is 100% OK, tho I have multiplied it 50 times (nothing scary for Rhino when I do so from my OLD laptop). Why is Rhino running out of memory if only 30% is being used? Why I feel Rhino mixing the memory problem with topology of 3D geometry?
My PC is extremely powerful (see the attached Dell Precisin Optimize Analysis Report with the specs).
Even on my laptop at home I use legal version of Rhino! I work for big company in Paris and all software (including Rhino is 100% legal!). Few month ago I needed the serial number and I emailed Pascal with my data - he forwarded to me straight
I can’t tell if you’re running 32-bit V5 or 64-bit V5.
This would have a HUGE bearing on how much memory is available to Rhino.
Run the About command and read the detail above the large “Rhinoceros”.
Another cause of unexpected large memory usage are “Bad” objects.
If you run SelBadObjects does anything highlight?
