Maybe Bug in "Surface Split" function?
Hi forum…
I’m desperate… I try to splitt a cyclinder with lines. But in addition to splitting the cyclinder with lines it is splitted at the cplane as well.
Is this a bug or a feature?
Thank you very much…
surfacesplitbug.gh (12.0 KB)
It’s the seam of your surface.
is there a way to remove this seam?`
No, a surface is always square.
But you can change your logic and move the seam to a place where it doesn’t hurt.
Instead of creating a pipe and then splitting its surface, you could also split the circle and extrude the segments.
tübbing.gh (12.7 KB)
Thank you i did.
Now i have the problem the order of the surfaces is unstructured. is there a way to order the surfaces?
i have to cut 2 specific surfaces later to make a parametric fea model.
surfacesplitbug.gh (11.4 KB)
Not if you use Martin´s method, which is a much cleaner and robust approach in my humble opinion.
Hi, @David_Seidel1
You mean order them like that?
surfacesplitbug polar.gh (20.4 KB)
