Material Rendering Artifacts at certain angles in "Rendered" viewport
Some of the materials in my scene are displaying artifacts in the textures when viewed at certain angles in the “rendered” viewport. Moving the camera seems to fix it until it gets to another angle it doesn’t like. I have tried adjusting the render mesh settings and it still happens. Not sure where to go from here.
Rhino Materia.3dm (7.3 MB)
I’m not seeing that, but it looks like bump mapping…which there doesn’t seem to be any of in your file. Maybe it’s a texture filtering thing… so what does it look like with an actual render? And run -systemInfo and post the results.
Rendering is fine, but I won’t use that. I want the viewport to work for my purposes.
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001, Git hash:master @ b14fcd901289f8715631debb308bc919a4988e07)
License type: Commercial, build 2025-03-07
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Ti (NVidia) Memory: 8GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
G:\Castaneda Engineering\CAD References_Commands\Rhino\RATplus_071118\Rhino\RATplus_071118.rhp “Rhino.NET SDK” 0.0.0.0
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25066.7001
It appears to have something to do with the distance from the origin (it is currently about 2000’ away). If I move everything to the origin, then it works fine. I would really prefer not to move the geometry as it is relative to a large point cloud.
Well OpenGL shadowing has a LOT to do with those sorts of properties of the scene, so…sorry.
