Material missing when transfer model to anader computer
Hi. I have problems whid displaying material when I transfer my model between computers. I try to copy th complete material library between computers bur still dont go. Any sugestion?
Thanks in advance, Rino.
Try checking the option to embed textures if you are using Rhino Renderer or Brazil as the render plugin. This is located in Options>Document Properties>Rendering. Then save the 3dm file again to embed the textures in the materials and environments in the file. You can also use the Save Textures check box in the Save As dialog for this. If you are using a different rendering plugin you will need to embed the textures in that plugins material options.
