mema jioni newsgroup !
The Match Properties dialog doesn not close with RMB on the viewport. Shouldn`t it get closed with OK instead of repeating the last command ?
thank you,
clement
thank you,
clement
Hi Clement,
That’s working here for me using Rhino 5 SR4. My steps were…
1- run MatchProperties
2- sel object to modify
3- RMB
4- sel source object
5- RMB with the cursor over the viewport
5 closed the dialog for Match Props. Are you saying it doesn’t close and you start running the MatchProperties command again?
Hi Brian,
i think my description was confusing. I`m not running the MatchProperties command, i´ve meant the Match button in the properties dialog which basically runs the same dialog:
On my system (SR5) it is repeating the _Circle command instead of closing the Match Properties dialog.
c.
Thanks for the clarification C. I see the bug here too in SR4 now and have filed it as
http://mcneel.myjetbrains.com/youtrack/issue/RH-19795
(you can’t see this publicly yet but that’s planned)
Thanks Brian for filing it.
c.
I see the similar problem as well. Basically, match button ( in the properties bar) doesn’t work. Today I downloaded the newest update and it still doesn’t work.
thank you and good luck guys
confirmed. It`s not working as it should.
c.
