Help . . . Match all properties script doesnt work anymore
Hí guys, sombody made this very useful match all properties script. I could put it under a button and one klick would just match everything possible without any additional dialog.
I got so used to that an now it doesnt work anymore, can somebody pls provide a new one.
I am running V5 SR9.
Thanks for the help, Oliver
Hi Oliver- what happens? Is there an error message?
Hi Pascal,
actually it doesnt do anything.
Command: MatchAllProperties …thats it.
When i drag and drop the script file onto the screen again it shows the following
Command: _-LoadScript
Unknown command: _-LoadScript
Thank you, Oliver
Hi Oliver-
it sounds like RhinoScript is not loading at all. Can you look in Options > Plug-ins for Rhino Script?
The rhinoscript was not loaded, now it is and it shows me this message . . .
THX Oliver
OK- - now, drag and drop the script again - that should set it up to work as expected.’
Pascal, it works again,
makes my day a lot easier . . .
thanks for your help,
Greeting from Hamburg, Oliver
