Hi, can we use 3 points to set the revit plane like what we did in Rhino? Or can we set a work plane in Rhino then let Revit follow that plane using RIR?
I think it would make life easier if you can set the work plane freely in the Revit 3D view
Unfortunately there isn’t a Revit API method to set the active workplane for a view, its only available to set through the Revit UI.
