I wonder if there is a way to use Rhino.Inside within the Revit edit mode.
When we are within an edit mode (like Edit Boundary or Edit Profile), to modify lines, I prefer to use Rhino, because it has a lot of ways to modify curves. But I found that it is impossible to pass curves from Rhino to Revit at this moment…
I wonder if there is any tricks to achieve this?
You can use the component called host boundary profile to edit elements like floors/ceilings… you can also edit linear elements like beams etc using the element curve component.
