Making an arc between each of the curves
I’m trying to make the arc as shown in the photo attached however I am having trouble understanding how lists work. I tried taking a stab at it however to no avail.
Curve Divide.3dm (179.9 KB)
Curve Divide.gh (15.0 KB)
Here’s a simple solution:
In order to build the ‘arcs’ you need a tree structure.
You start with 1 closed curve and divide it into 100 segments. These segments will have a path index from {0} to {99}. The curve start and end point are projected or pulled to your surface. Using a midpoint component doesn’t require sorting or culling anything.
Curve Divide.gh (23.6 KB)
Some similar topics
