I have a simple problem that I just cannot seem to figure out. I have two sets of smaller circles arranged along a larger circle. I want to draw the arcs (the same radius as the larger circle) between the smaller circles. I was able to get this to work for the outer set (you can see it highlighted in green), I did this by solving the intersection between the smaller circles and the larger one. But when I try to do this same process for the inner set, the start and end of the list are flipped (see numbers). I think this is a problem with the Curve/Curve Intersection component, does anyone have any other ideas on how I might accomplish this?
Thanks
Problem.gh (172.2 KB)
3 files
