make2d - separate silouhette
Hello, I was wondering if you could get a make2d result from a model that separates silhouette lines from the inner lines. Basically, what I’m looking for is a way to get lines like in the pen display option that I can then transfer to illustrator. thanks!
Hi Neta- it is not built in to Make2D but you can use CurveBoolean for this on the Make2D results.
Thanks Pascal! That’s great, I didn’t know about that command, but is there a way to get silhouettes of individual polysurfaces, more like in the image? (the thicker lines)
If I try curveboolean it gives me the outline of all the polysurfaces together.
Not sure if this is what you want but if you are going for outlines of the individual buildings that are visible from a front view of a 3d model without showing all the hidden and internal lines you can try the following.
