I have done an axonometric and decided to make it as 2d drawing but it isn’t showing up as a lines although I can pick it up on the front view. Do you know how to fix this
can you share the file?
if not, check the layer color… it may simply be displaying the same color as your background.
if you hit ctrl+a to select all, then set it to black in the object properties, does it show up?
Hi Nicole! “Make 2D” will create a brand new layer called “Make 2D”. There you can access your new 2D drawings.
