Make 2d drawing problem
when i make 2d Drawing i get nothing .
i do it from perspective view and i only get like 3 lines that dont even touch. and the size of the drawing is super tiny
Hi @jokoqui_m, I would 1st check to see how many layers have been created after running make2d. Normally there is a new layer with sub layers for each type of linetype chosen eg. hidden details etc.
You can then right click on the layers and select objects.
This should show up all the linework that was made per layer.
Also to note that hidden detail often defaults to white in colour which then disappears if your viewport background colour is white too.
MIchael VS
