Make2D isn't generating
As of yesterday, my make2D has been refusing to generate. I’ve tried resetting my computer, moving the model to a new file, and resizing it, but it continues to crash. Is there a way to fix this? I’m in desperate need of help.
For reference, I am a uni student and am currently using Rhino 8
Hi lyanna,
The file doesn’t appear to be very large (14mb)
Please run the SystemInfo command in rhino and post the result.
You may have bad objects (try the SelBadObjects command) or a really high tolerance (mm file with .0001 for example)
https://wiki.mcneel.com/rhino/make2dtips
Hello Japhy,
Thank you so much for replying. I just tried the SelBadObjects and it says I have no bad objects. The information from the SystemInfo command is below:
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Educational, build 2024-09-10
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.7
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\Lpslo\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Lumion-LiveSync-for-Rhino\3.60.65\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\export_AI.rhp “Adobe Illustrator Export”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
nothing really jumping out in your SystemInfo.
Can you post the file? if it needs to be privately please send via this link. thanks
Running the Units command and changing the Absolute tolerance to .1 vs .001 it ran as expected. With the higher tolerance it will finish but might take a while.
It’s still not working for me, I was wondering if it could have something to do with storage?
I think the next step would be to disable lumion and restart Rhino.
Here are the settings i used on the Right view.
