Make 2d issue
Hey, I have a model which i made up of linked blocks, my make 2d has been working perfectly ecah time but now all of a sudden it stops working. To make my plans, exploding the blocks seems to help however with my axo and section it doesnt. The make 2d either comes up empty or with some few lines.
Any advice ?
Hi Magna -
Please run the Rhino SystemInfo and copy-paste its output here.
Rhino 8 SR30 2026-4-13 (Rhino 8, 8.30.26103.11002, Git hash:master @ 3ad61623b0ac4561e2f13265580c56a9f50596d8)
License type: Educational, build 2026-04-13
License details: Cloud Zoo
Apple macOS Version 15.0.1 (Build 24A348) (Physical RAM: 16GB)
Mac Model Identifier: Mac14,10
Language: en-GB (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.30.26103.11002
Hi Magna -
Thanks.
I’ve tried to reproduce this issue with a few simple files and that went fine here.
When you create just a few simple shapes in different files and insert those as linked blocks in a new file, does Make2D then work as expected?
If not, which are the exact settings that you are using when inserting files?
