Hey,
I’ve got a problem with the make2D command, I want to convert an isometric view into a 2D Drawing and used 2 Clipping planes because it should be from a section of the whole Building.
The Make2d command does work and some objects are getting cut, but some aren’t being cut and I can’t figure out why, I checked the settings, the clipping plane are set to cut everything.
maybe someone can help me with the problem.
