Hello, I know if this is expected behavior, but it seems like when I use the selective clipping feature to create a section, the other things that aren’t clipped don’t work with Make2D?
The section plane is cutting through the object in black, which is not selected. I just want to Make2D on the other objects, which I am able to highlight, but it just tells me “No output geometry found. Nothing done”
However, you can see that the section plane includes only the objects in the fishery, and not the other stuff.
The file is attached.
section tool error.3dm (12.5 MB)
