Hi everyone, I arrayed a set of two curves around a curve and I’m having a hard time making the curves parallel to the XY plane. I tried the orient component but it didn’t work as expected. In the image below you see the curves following the curve, not the XY plane. Also, I tried to build the curves on horizontal frames instead of using the array curve, but I ended up with half of the curves rotated 180 degrees (pointy edge of curves don’t align, see the second image)
ArrayedCurves.gh (21.6 KB)
