I’m working on an scheme bridge formed by a section (deck) along a curved path (spline).
I have divided the length of the curve and now want to place the section of the deck at each point along the curve by using ‘orient’ tool (to orient both planes xz). Half of the curves appear to be turned 180 degrees on the xz axis, and I dont know why.
The “Plane Normal” component you’re using doesn’t have enough information to know how to orient its X and Y axes, so it chooses arbitrarily.
Use Align Plane afterwards to align it with your Z axis or construct it differently in the first place -Perpendicular Frames along your curve?
Thanks @HS_Kim, I got it already. I aligned the planes, along the curve and had to rotate them as well, because the new section came up all the way round.
Thank you!180404.3dm (21.8 KB) 180404_re.gh (32.4 KB)
