How can I orient all of my planes generated by the curve frame component in the same direction? I want all of my planes oriented so that x is aligned to the curve and y is oriented perpendicular and facing outward. Currently the y axis alternates with some facing outward and others inward. Thanks!
If you use Perp Frames instead of Curve Frames you will get planes with their Z axis (blue) aligned to the curve and X/Y axes (red and green) perpendicular to the curve. But their direction is dependent on curvature unless you re-align them otherwise.
