I’m trying to extract a few drawing from a 3d model but the fences are always missing on the make2d. I have lower the tolerence until 0.1 but this won’t change anything. Weeks ago i made a few make 2d with the same fences and this was working completly fine.
Hi Patrick,
Can you post your file here or send to McNeel?
How far away from the origin (0,0,0) is the model? Do the Railings make 2D on their own? Are they radiused or square balusters?
yes i will send it right now. They are square you will see
Thanks a lot
The Balusters are actually circular. Not a big deal though, just computationally more intense.
I’m not having any issues.
Can you type SystemInfo into the command line and post the results here.
My system info
Rhino 7 SR19 2022-5-25 (Rhino 7, 7.19.22145.11571, Git hash:master @ caa2c82dfec916fac8d9d68494573e8d3883ef60)
License type: Commercial, build 2022-05-25
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 64Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 2070 Super (NVidia) Memory: 8GB, Driver date: 7-7-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.35
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-7-2021
Driver Version: 30.0.14.7135
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Users\jw\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\LayoutManager (23664189-f095-4e9c-8f6d-1073c2c60efc)\0.2.6.0\LayoutManager.rhp “LayoutManager” 0.2.6.0
C:\Users\jw\AppData\Roaming\Grasshopper\Libraries\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\jw\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\VoxelMesh (c40b0849-f145-4aaa-adec-897c8b9575f6)\1.0.0.0\VoxelMesh.rhp “VoxelMesh” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\jw\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.19.22145.11571
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.19.22145.11571
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.19.22145.11571
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.19.22145.11571
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.19.22145.11571
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Éducation, build 2022-05-04
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 7-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.41
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 7-12-2021
Driver Version: 30.0.14.7141
Total Video Memory: 4 GB
C:\Users\papag\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “ConnectorRhino7” 2.2.4.8364
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
Lets eliminate the 3rd party variables first.
Go to file>properties>plugins and uncheck the Vray and Speckle. Restart Rhino and try the Make2d again.
i made a specific file to send it to you. It doesn’t work on the file i’m working on but it does on the one i sent to you. (even wihout turning of vray and speckle)
Interesting. Can you run SelBadObjects in the bad file. Are the tolerances or anything different? Lots of variables now, at least you have a way forward, but it would be nice to figure out why the particular file is failing. Can you send that one as well? Thanks.
