Hi All
So a question on macros - something I’ve always wondered about, but has just worked around so far:
Is there a way to set command options in macros that would work with pre-selections? An example: I have “ExtractSrf Copy=Yes” and “ExtractSrf Copy=No” as separate aliases, which works fine - but not with pre-selection. I can insert SelNone and SelPrev to get it to work with pre-selection, but then it doesn’t work without. I’m sure it could be scripted, but I’m not able to ('cause I’m dumb) and also this is more of a general question on the abilities of macros.
TIA, Jakob
