trying to set ‘copy’ option to ‘no’ for ExtractSrf
for example, this works:
_move vertical=yes 0 _pause _selnone
but this doesn’t:
_extractsrf copy=no
thnx!
but this doesn’t:
_extractsrf copy=no
thnx!
Hi -
That appears to be working fine here.
Which version of Rhino are you trying this on?
on the latest I think: Version 6 SR29
it’s reading copy=no as a command, instead of an option
thnx @wim
Hello - Can you please get a few more lines of the command history? F2 will open a window with the entire recent history.
here you go!
thnx @pascal
Hello - I guess you are preselecting a face with sub-object selection? The command was not, I guess, originally intended to be used with preselection. I will see if this can be tuned up…
RH-61071 ExtractSrf - Copy option with preselection
I see! thnx Pascal
awesome!
(now little things like this helps: ‘poly surfaces’)
