_-SelLayer _Pick
When using the above, pre-selected objects are being ignored. Is this intended or a bug? If it is intended, how can I change the command to include pre-selected objects? If not, it should be changed to include pre-selected objects.
Thanks, S
Its working here. Maybe I’m reading it wrong.
I got some objects on different layers. So I start with.
Selecting an object
-_Sellayer _pick
Select my object
Press enter
And my pre selected objects are still selected.
In your script. Did you use _Pause after _Pick?
Hi Jordy
Thanks for your reply. What I was looking for is the following:
pre-select an object
-_SelLayer _Pick
enter
get all objects on the layer of the object that was pre-selected. Yes, I am using pause in the macro, it is an excerpt of a longer macro.
Thanks,
Silvan
You can do this I gues
1. Pre-select an object
2. -_selnone -_sellayer _pick _selprev
3. Enter
Thanks! This works for me.
pascal
(Pascal Golay)
August 12, 2014, 3:42pm
6
Probably intentional- otherwise it would be hard to add a layer to the current selection.
