I am trying to load a project in Visual Studio Mac, but I cannot reference RhinoCommon properly.
I tried to install Rhinocommon via package manager but the reference is till not recognised. How can I reference assemblies in Mac Visual Studio?
Hi @Petras1, it’s been a long time since I did it, but I believe everything is explained there : Installing Tools (Mac) with C#
Install the tools found there and load it then from visual studio>extensions
Thanks for the tutorial @flixchameroy . The tutotial is about creating a new project based on a template.
But how do you reference rhinocommon for an empty c# ? I am a newbie on mac and possibly missing smth simple.
On the menu bar, go to Project>Add Reference ?
And for mac I can reference the same rhinocommon.dll? Is this .dll typically found in application folder?
I’m really no specialist but I think yes.
RhinoCommon.dll is typically found at /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Versions/A/Resources/RhinoCommon.dll, you can browse to there while adding a .Net Assembly
You might also need RhinoUi.dll which you can find in the same folder, and Grasshopper.dll or GH_IO.dll, which you’ll get at /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Versions/A/Resources/ManagedPlugIns/GrasshopperPlugin.rhp/Grasshopper.dll
It seems windows visual studio projects dont simply work on mac. It only works if I create new grasshopper visual studio project and copy paste the .cs files.
The .csproj format is cross-platform, but older projects may use platform-specific elements such as post-build steps that rely on commands that are only present on one operating system (i.e. Copy).
Here’s an example of a cross-platform .csproj (using the modern sdk-style format) that’s generated by the current Rhino 7 C# project template…
<Project Sdk="Microsoft.NET.Sdk">
<PropertyGroup>
<TargetFramework>net48</TargetFramework>
<Version>1.0</Version>
<Title>rhino_test</Title>
<Description>Description of rhino_test</Description>
<TargetExt>.gha</TargetExt>
</PropertyGroup>
<ItemGroup>
<PackageReference Include="Grasshopper" Version="7.4.21078.1001" IncludeAssets="compile;build" />
</ItemGroup>
<PropertyGroup Condition="$(Configuration) == 'Debug' AND $([MSBuild]::IsOSPlatform(Windows))">
<StartProgram>C:\Program Files\Rhino 7\System\Rhino.exe</StartProgram>
<StartArguments></StartArguments>
<StartAction>Program</StartAction>
</PropertyGroup>
</Project>
It uses TargetExt to set the extension instead of a post-build step.
Thank you @will
It seems that my project is 2-3 years old, meaning this post-build was causing troubles. I am glad the newer template is more cross-platform friendly.
