Tom_P
February 15, 2023, 1:19pm
1
Answering another topic - i came over the following bug:
To insert spaces in a macro we need (“unisex”) double quotes.
-_SelLayer "Layer 01"
the mac Macroeditor will autocorrect this to
-_sellayer “Layer 01”
with opening / closing double quotes.
this will not run
kind regards -tom
Gijs
(Gijs de Zwart)
February 28, 2023, 3:30pm
2
@Tom_P I’m not seeing this in either V7 or V8. I suspect it is related to language setting. How’s yours set?
Tom_P
February 28, 2023, 3:43pm
3
Gijs de Zwart:
language setting
both
english english
mac os and rhino
mac os x 10.15.7 - (quite old - sorry) ?
Gijs
(Gijs de Zwart)
February 28, 2023, 3:47pm
4
I just found this is a mac systems setting. In Keyboard settings, under Text, there is something called “use smart quotation marks” with settings for double and single quotes.
Tom_P
February 28, 2023, 4:17pm
5
yes it is a system setting.
but it should also be possible, to set it per textfield / UI
so i think the macroeditor should not rely on the systemsetting
not sure if it is exactly the correct hit…
but something like this:
should be set for the MacroEditor.
it is possible to have a single text-window that does not rely on system settings:
just checked:
bbedit does not rely on this system setting.
Textedit does only use it for formated text.
it ignors this setting for unformated text:
Gijs
(Gijs de Zwart)
February 28, 2023, 5:30pm
6
Hi Tom, thanks for that info.
I’ve made RH-73307 Macro Editor double quotation marks depend on system settings
Tom_P
February 28, 2023, 6:40pm
7
thanks.
great - this will make the mac macro-editor more robust…
brian
(Brian Gillespie)
February 28, 2023, 11:54pm
8
RH-73307 is fixed in the latest WIP
